Salta al contenuto principale
Nokia 6010 motherboard replacement
Cosa ti serve
  1.  Nokia 6010 motherboard replacement, Battery: passo 1, immagine 1 di 3  Nokia 6010 motherboard replacement, Battery: passo 1, immagine 2 di 3  Nokia 6010 motherboard replacement, Battery: passo 1, immagine 3 di 3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2.  Nokia 6010 motherboard replacement: passo 2, immagine 1 di 2  Nokia 6010 motherboard replacement: passo 2, immagine 2 di 2
    • Lift the battery near the bottom and pry up.
  3.  Nokia 6010 motherboard replacement, SIM Card: passo 3, immagine 1 di 1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4.  Nokia 6010 motherboard replacement, Keypad: passo 4, immagine 1 di 2  Nokia 6010 motherboard replacement, Keypad: passo 4, immagine 2 di 2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5.  Nokia 6010 motherboard replacement: passo 5, immagine 1 di 1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
  6.  Nokia 6010 motherboard replacement, LCD Screen and Speaker: passo 6, immagine 1 di 2  Nokia 6010 motherboard replacement, LCD Screen and Speaker: passo 6, immagine 2 di 2
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
  7.  Nokia 6010 motherboard replacement: passo 7, immagine 1 di 3  Nokia 6010 motherboard replacement: passo 7, immagine 2 di 3  Nokia 6010 motherboard replacement: passo 7, immagine 3 di 3
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
  8.  Nokia 6010 motherboard replacement, Logic Board: passo 8, immagine 1 di 2  Nokia 6010 motherboard replacement, Logic Board: passo 8, immagine 2 di 2
    • Slide the rubber power button away from the body of the phone.
    • The power button is the rubber piece on the top of the phone.
  9.  Nokia 6010 motherboard replacement: passo 9, immagine 1 di 3  Nokia 6010 motherboard replacement: passo 9, immagine 2 di 3  Nokia 6010 motherboard replacement: passo 9, immagine 3 di 3
    • Insert a finger between the phone body and logic board.
    • The logic board is the green plastic piece with circuitry attached.
    • Pull the board away gently.
    • The board is delicate and contains electronic parts. Be careful while removing it.
Conclusione
Cal Poly, Team 14-45, Regan Winter 2010 Membro di Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 5,343
