Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
  1. Unlock the lock latch on the left. Unlock the lock latch on the right. Remove the battery while holding the lock latch unlocked.
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover. Lift the bottom right cover with the iFixit Opening Tool. Lift the lower left cover with the iFixit Opening Tool.
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Lift the bottom right cover with the iFixit Opening Tool.
    • Lift the lower left cover with the iFixit Opening Tool.
    • Finally clear the bottom cover completely to access the main components.
  4. First disconnect one of the antenna connectors. Then the other connector. Unscrew the fixing screw with the Philips # 0 screwdriver. Then slightly lift the chipset and remove it from the mSATA connector.
    • First disconnect one of the antenna connectors.
    • Then the other connector.
    • Unscrew the fixing screw with the Philips # 0 screwdriver. Then slightly lift the chipset and remove it from the mSATA connector.
Conclusione
TO REASSEMBLE YOUR DEVICE FOLLOW THE FOLLOWING INSTRUCTIONS IN REVERSE ORDER.
Un ringraziamento speciale a questi traduttori:
100%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Felice Suglia
Membro da: 15/06/2013
14.904 Reputazione
150 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 45
