Salta al contenuto principale
why! W650SZ Keyboard Replacement
Cosa ti serve
  1. why! W650SZ Keyboard Replacement, Battery: passo 1, immagine 1 di 3 why! W650SZ Keyboard Replacement, Battery: passo 1, immagine 2 di 3 why! W650SZ Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: passo 2, immagine 1 di 3 why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: passo 2, immagine 2 di 3 why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: passo 2, immagine 3 di 3
    • With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
    • Now you can remove the bottom cover.
  3. why! W650SZ Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 why! W650SZ Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 why! W650SZ Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Press gently at the points indicated to release the LED cover strip.
    • Turn the laptop over, then lift the LED cover.
    • Remove the LED cover.
  4. why! W650SZ Keyboard Replacement: passo 4, immagine 1 di 3 why! W650SZ Keyboard Replacement: passo 4, immagine 2 di 3 why! W650SZ Keyboard Replacement: passo 4, immagine 3 di 3
    • The five screws that anchor the keyboard are now visible.
    • Start by removing the first screw.
    • Remove the remaining screws (2-5).
  5. why! W650SZ Keyboard Replacement: passo 5, immagine 1 di 3 why! W650SZ Keyboard Replacement: passo 5, immagine 2 di 3 why! W650SZ Keyboard Replacement: passo 5, immagine 3 di 3
    • Dismount the keyboard from the chassis.
    • Flip the keyboard forward, taking care as it is still connected by a cable to the motherboard.
    • Release the cable latch on the right side of the motherboard connector with a small flat blade screwdriver.
  6. why! W650SZ Keyboard Replacement: passo 6, immagine 1 di 3 why! W650SZ Keyboard Replacement: passo 6, immagine 2 di 3 why! W650SZ Keyboard Replacement: passo 6, immagine 3 di 3
    • Release the cable latch on the left side of the motherboard connector.
    • Slide the cable straight out from its connector.
    • Remove the keyboard.
Conclusione
Un ringraziamento speciale a questi traduttori:
fr en
100%
Jerry Wheeler ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Felice Suglia
Membro da: 06/15/13
33.562 Reputazione
283 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 33
Tutti i Tempi: 348
