Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
  1. Open the latch of the accumulator on the left side. Open the battery latch on the right side. Remove the accumulator by simultaneously holding the right-hand latch open.
    • Open the latch of the accumulator on the left side.
    • Open the battery latch on the right side.
    • Remove the accumulator by simultaneously holding the right-hand latch open.
  2. Use the Philips screwdriver to remove the two screws at the bottom of the cover. Lift the cover at the bottom right with the iFixit Opening Tool Lift the cover at the bottom left with the iFixit Opening Tool
    • Use the Philips screwdriver to remove the two screws at the bottom of the cover.
    • Lift the cover at the bottom right with the iFixit Opening Tool
    • Lift the cover at the bottom left with the iFixit Opening Tool
    • Finally, remove the cover to gain access to the most important components.
  3. Once the bottom cover is removed you can start disassembling the keyboard. First, invert the calculator and then loosen the screw as shown in picture 2 of this step. Then unzip the keyboard screw cover strip.
    • Once the bottom cover is removed you can start disassembling the keyboard.
    • First, invert the calculator and then loosen the screw as shown in picture 2 of this step.
    • Then unzip the keyboard screw cover strip.
  4. Kit per Nintendo Switch
    Una soluzione rapida per tornare in gioco
    Acquista Kit per Switch
  5. After the cover strip is removed, you can see the tip of the screwdriver. Now locate the five fastening screws of the keyboard. Loosen these five screws.
    • After the cover strip is removed, you can see the tip of the screwdriver.
    • Now locate the five fastening screws of the keyboard.
    • Loosen these five screws.
  6. Lift the keyboard slightly and pull it slightly backwards. The connection cables are now visible. Now release the right lock on the plug of the keyboard light cable.
    • Lift the keyboard slightly and pull it slightly backwards.
    • The connection cables are now visible.
    • Now release the right lock on the plug of the keyboard light cable.
  7. Then the left lock. Now apply the same procedure to the plug of the main cable (left lock) Right lock.
    • Then the left lock.
    • Now apply the same procedure to the plug of the main cable (left lock)
    • Right lock.
  8. You can now remove the keyboard from its slot.
    • You can now remove the keyboard from its slot.
Conclusione
Repeat the steps in order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
100%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Felice Suglia
Membro da: 15/06/2013
14.904 Reputazione
150 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 79
