Salta al contenuto principale
why! N240JU Replacement motherboard
Cosa ti serve
  1. why! N240JU Replacement motherboard, Battery: passo 1, immagine 1 di 2 why! N240JU Replacement motherboard, Battery: passo 1, immagine 2 di 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacement motherboard, Access to main components: passo 2, immagine 1 di 2 why! N240JU Replacement motherboard, Access to main components: passo 2, immagine 2 di 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacement motherboard: passo 3, immagine 1 di 3 why! N240JU Replacement motherboard: passo 3, immagine 2 di 3 why! N240JU Replacement motherboard: passo 3, immagine 3 di 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacement motherboard, SSD M.2 disk: passo 4, immagine 1 di 3 why! N240JU Replacement motherboard, SSD M.2 disk: passo 4, immagine 2 di 3 why! N240JU Replacement motherboard, SSD M.2 disk: passo 4, immagine 3 di 3
    • Locate the M.2 SSD in its slot.
    • Unscrew the fastening screw of the latter.
    • Lift and remove the SSD M.2 drive from its connector.
  5. why! N240JU Replacement motherboard, Hard disk (mass storage): passo 5, immagine 1 di 3 why! N240JU Replacement motherboard, Hard disk (mass storage): passo 5, immagine 2 di 3 why! N240JU Replacement motherboard, Hard disk (mass storage): passo 5, immagine 3 di 3
    • Locate the hard drive in its location.
    • Lift it slightly.
    • Finally remove it from its SATA connector.
  6. why! N240JU Replacement motherboard, BIOS stack: passo 6, immagine 1 di 2 why! N240JU Replacement motherboard, BIOS stack: passo 6, immagine 2 di 2
    • To reassemble your device, follow the instructions in reverse order.
    • Lift it gently and take it out of its place.
  7. why! N240JU Replacement motherboard, WLAN card: passo 7, immagine 1 di 2 why! N240JU Replacement motherboard, WLAN card: passo 7, immagine 2 di 2
    • Carefully unplug the MAIN and AUX antennas.
    • Unscrew the fixing screw with the Philips # 0 screwdriver. Then lift the chipset slightly and remove it from the connector.
  8. why! N240JU Replacement motherboard, RAM Memory: passo 8, immagine 1 di 3 why! N240JU Replacement motherboard, RAM Memory: passo 8, immagine 2 di 3 why! N240JU Replacement motherboard, RAM Memory: passo 8, immagine 3 di 3
    • Find and separate the spring blades that maintain the memory module in place (right).
    • Find and separate the spring blades that maintain the memory module in place (left).
    • Remove the memory module (RAM) from its connector.
  9. why! N240JU Replacement motherboard, The fan: passo 9, immagine 1 di 3 why! N240JU Replacement motherboard, The fan: passo 9, immagine 2 di 3 why! N240JU Replacement motherboard, The fan: passo 9, immagine 3 di 3
    • Remove the power cable from the fan.
    • Unscrew the two screws securing the fan.
    • Finally remove the fan and place it on your worktop.
  10. why! N240JU Replacement motherboard, The keyboard: passo 10, immagine 1 di 3 why! N240JU Replacement motherboard, The keyboard: passo 10, immagine 2 di 3 why! N240JU Replacement motherboard, The keyboard: passo 10, immagine 3 di 3
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  11. why! N240JU Replacement motherboard: passo 11, immagine 1 di 3 why! N240JU Replacement motherboard: passo 11, immagine 2 di 3 why! N240JU Replacement motherboard: passo 11, immagine 3 di 3
    • Disconnect the connector circled in red in the direction of the arrow
  12. why! N240JU Replacement motherboard, Motherboard: passo 12, immagine 1 di 3 why! N240JU Replacement motherboard, Motherboard: passo 12, immagine 2 di 3 why! N240JU Replacement motherboard, Motherboard: passo 12, immagine 3 di 3
    • Locate the two flat cables and remove them carefully.
  13. why! N240JU Replacement motherboard: passo 13, immagine 1 di 3 why! N240JU Replacement motherboard: passo 13, immagine 2 di 3 why! N240JU Replacement motherboard: passo 13, immagine 3 di 3
    • Locate the five connectors on the motherboard
    • Unplug all connectors
  14. why! N240JU Replacement motherboard: passo 14, immagine 1 di 3 why! N240JU Replacement motherboard: passo 14, immagine 2 di 3 why! N240JU Replacement motherboard: passo 14, immagine 3 di 3
  15. why! N240JU Replacement motherboard: passo 15, immagine 1 di 2 why! N240JU Replacement motherboard: passo 15, immagine 2 di 2
    • Unscrew the four screws circled in red
    • Lift the motherboard by taking it through the radiator
  16. why! N240JU Replacement motherboard: passo 16, immagine 1 di 3 why! N240JU Replacement motherboard: passo 16, immagine 2 di 3 why! N240JU Replacement motherboard: passo 16, immagine 3 di 3
    • Disconnect the two connectors circled in red
Conclusione
Un ringraziamento speciale a questi traduttori:
fr en
100%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Felice Suglia
Membro da: 06/15/13
29.001 Reputazione
244 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 300
