Salta al contenuto principale
why! N131WU/BU/ZU RAM Replacement
Cosa ti serve
  1. why! N131WU/BU/ZU RAM Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: passo 2, immagine 1 di 3 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: passo 2, immagine 2 di 3 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: passo 2, immagine 3 di 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: passo 3, immagine 1 di 3 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: passo 3, immagine 2 di 3 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: passo 3, immagine 3 di 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: passo 4, immagine 1 di 2 why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: passo 4, immagine 2 di 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU/BU/ZU RAM Replacement, RAM (Memory): passo 5, immagine 1 di 3 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): passo 5, immagine 2 di 3 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): passo 5, immagine 3 di 3
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
Conclusione
To reassemble your device, follow the instructions in reverse order.
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Felice Suglia
Membro da: 06/15/13
30.908 Reputazione
264 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 387
