Salta al contenuto principale
uAttend bn6000 Fingerprint Replacement
Cosa ti serve
  1. uAttend bn6000 Fingerprint Replacement, Disassembly: passo 1, immagine 1 di 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Fingerprint Replacement: passo 2, immagine 1 di 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Fingerprint Replacement, Fingerprint: passo 3, immagine 1 di 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: passo 3, immagine 2 di 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: passo 3, immagine 3 di 3
    • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
  4. uAttend bn6000 Fingerprint Replacement: passo 4, immagine 1 di 3 uAttend bn6000 Fingerprint Replacement: passo 4, immagine 2 di 3 uAttend bn6000 Fingerprint Replacement: passo 4, immagine 3 di 3
    • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
Conclusione
To reassemble , follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 548
