Salta al contenuto principale
Introduzione
It will be briefly shown how to remove the panel and a little tip's up there.
  1. These two pins must be removed.
    • These two pins must be removed.
  2. Here, a screwdriver or other stable thin object (in the picture: letter opener) can be helpful
    • Here, a screwdriver or other stable thin object (in the picture: letter opener) can be helpful
  3. TIP: if you remove the cladding more often (for example, for thorough cleaning), it may be helpful to provide the splints with some insulating tape, so the use of tools is unnecessary TIP: if you remove the cladding more often (for example, for thorough cleaning), it may be helpful to provide the splints with some insulating tape, so the use of tools is unnecessary
    • TIP: if you remove the cladding more often (for example, for thorough cleaning), it may be helpful to provide the splints with some insulating tape, so the use of tools is unnecessary
  4. The panel is now dismantled
    • The panel is now dismantled
Conclusione
Repeat the steps in order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
de en
100%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Leonard Kesting
Membro da: 14/08/2016
1.194 Reputazione
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 112
