Salta al contenuto principale
ring Indoor Cam Camera Replacement
Cosa ti serve
  1. ring Indoor Cam Camera Replacement, Body: passo 1, immagine 1 di 3 ring Indoor Cam Camera Replacement, Body: passo 1, immagine 2 di 3 ring Indoor Cam Camera Replacement, Body: passo 1, immagine 3 di 3
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
  2. ring Indoor Cam Camera Replacement: passo 2, immagine 1 di 2 ring Indoor Cam Camera Replacement: passo 2, immagine 2 di 2
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
  3. ring Indoor Cam Camera Replacement: passo 3, immagine 1 di 2 ring Indoor Cam Camera Replacement: passo 3, immagine 2 di 2
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
  4. ring Indoor Cam Camera Replacement: passo 4, immagine 1 di 3 ring Indoor Cam Camera Replacement: passo 4, immagine 2 di 3 ring Indoor Cam Camera Replacement: passo 4, immagine 3 di 3
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
  5. ring Indoor Cam Camera Replacement, Motherboard: passo 5, immagine 1 di 3 ring Indoor Cam Camera Replacement, Motherboard: passo 5, immagine 2 di 3 ring Indoor Cam Camera Replacement, Motherboard: passo 5, immagine 3 di 3
    • Gently remove the three white leads from their sockets on the top of the motherboard.
  6. ring Indoor Cam Camera Replacement: passo 6, immagine 1 di 2 ring Indoor Cam Camera Replacement: passo 6, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the two 4.7 mm black screws located in the corners of the motherboard.
    • Using a Phillips #00 screwdriver, remove the two silver 5 mm screws in the center of the motherboard.
  7. ring Indoor Cam Camera Replacement: passo 7, immagine 1 di 3 ring Indoor Cam Camera Replacement: passo 7, immagine 2 di 3 ring Indoor Cam Camera Replacement: passo 7, immagine 3 di 3
    • Use the iFixit opening pick to pry the motherboard from the body of the camera.
  8. ring Indoor Cam Camera Replacement: passo 8, immagine 1 di 2 ring Indoor Cam Camera Replacement: passo 8, immagine 2 di 2
    • Detach the black wire connecting the motherboard to the body of the camera.
  9. ring Indoor Cam Camera Replacement, Camera: passo 9, immagine 1 di 3 ring Indoor Cam Camera Replacement, Camera: passo 9, immagine 2 di 3 ring Indoor Cam Camera Replacement, Camera: passo 9, immagine 3 di 3
    • Gently turn to the motherboard's backside and remove the white leads connecting the camera to the socket in the motherboard.
    • Cautiously remove the camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 34
Tutti i Tempi: 203
