Salta al contenuto principale
ring Indoor Cam Body Replacement
Cosa ti serve
  1. ring Indoor Cam Body Replacement, Body: passo 1, immagine 1 di 3 ring Indoor Cam Body Replacement, Body: passo 1, immagine 2 di 3 ring Indoor Cam Body Replacement, Body: passo 1, immagine 3 di 3
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
  2. ring Indoor Cam Body Replacement: passo 2, immagine 1 di 2 ring Indoor Cam Body Replacement: passo 2, immagine 2 di 2
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
  3. ring Indoor Cam Body Replacement: passo 3, immagine 1 di 2 ring Indoor Cam Body Replacement: passo 3, immagine 2 di 2
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
  4. ring Indoor Cam Body Replacement: passo 4, immagine 1 di 3 ring Indoor Cam Body Replacement: passo 4, immagine 2 di 3 ring Indoor Cam Body Replacement: passo 4, immagine 3 di 3
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 25
Tutti i Tempi: 301
