Salta al contenuto principale
iView-776TPCII Rear Panel Replacement
Cosa ti serve
  1. iView-776TPCII Rear Panel Replacement, Rear Panel: passo 1, immagine 1 di 3 iView-776TPCII Rear Panel Replacement, Rear Panel: passo 1, immagine 2 di 3 iView-776TPCII Rear Panel Replacement, Rear Panel: passo 1, immagine 3 di 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
    Chiedi a FixBot
    Aggiungi Commento
  2. iView-776TPCII Rear Panel Replacement: passo 2, immagine 1 di 2 iView-776TPCII Rear Panel Replacement: passo 2, immagine 2 di 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
IUPUI, Team 2-2, Baechle Fall 2015 Membro di IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 50
Tutti i Tempi: 700
