Salta al contenuto principale
iVIEW-754TPC Speaker Replacement
Cosa ti serve
  1. iVIEW-754TPC Speaker Replacement, Rear Panel: passo 1, immagine 1 di 3 iVIEW-754TPC Speaker Replacement, Rear Panel: passo 1, immagine 2 di 3 iVIEW-754TPC Speaker Replacement, Rear Panel: passo 1, immagine 3 di 3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: passo 2, immagine 1 di 3 iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: passo 2, immagine 2 di 3 iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Desoldier wires from the mother board. Use soldier iron to disconnect wires from mother board. Use tweezers to pull wires as the iron is heating.
    • Remove yellow tape from the speakers and use tweezers to pull speaker out.
Conclusione
Robert Clark
Membro da: 01/21/15
1.065 Reputazione
7 Guide realizzate
USF Tampa, Team 5-4, Brown Winter 2015 Membro di USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 204
