Salta al contenuto principale
Introduzione
For this guide you will be removing rear wheels, then removing the outer shell and then replacing the motor.
Parti
Nessuna parte specificata.
  1. Remove the four exterior screws
    • Remove the four exterior screws
Conclusione
Joshua
Membro da: 24/10/2014
631 Reputazione
6 Guide realizzate
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Membri
7 Guide realizzate
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 186
