Cosa ti serve
To remove the auger simply pull it off
Then unscrew the four screws holding the plastic part in place
You can then pull that off revealing the piece that connects to the motor
The metal piece can now be replaced by inserting a new one
Remove the four exterior screws, and then the top plate.
Once the top plate is removed check the motors circuitry. Disconnect the motor and install the new motor.
