Salta al contenuto principale
iRobot Roomba i7 Front Bumper Replacement
Cosa ti serve
  1. iRobot Roomba i7 Front Bumper Replacement, Front Bumper: passo 1, immagine 1 di 3 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: passo 1, immagine 2 di 3 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: passo 1, immagine 3 di 3
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, unscrew the 6.27mm screw in the center of the side brush.
    • Using a Phillips #1 screwdriver, unscrew the 5 screws surrounding the bottom cover of the Roomba
  2. iRobot Roomba i7 Front Bumper Replacement: passo 2, immagine 1 di 3 iRobot Roomba i7 Front Bumper Replacement: passo 2, immagine 2 di 3 iRobot Roomba i7 Front Bumper Replacement: passo 2, immagine 3 di 3
    • Use the Philips #1 screw driver to remove the ten, 4.17 mm screws on the dislodged Bumper
  3. iRobot Roomba i7 Front Bumper Replacement: passo 3, immagine 1 di 2 iRobot Roomba i7 Front Bumper Replacement: passo 3, immagine 2 di 2
    • Once removed, readjust the bumper into its appropriate placement.
Conclusione
2 Commenti
My roomba seems to be blind some tomes it starts and just keeps on running into the walls over and over again sometime i rebbot it and it works and other times it doesnt work i dont know what wrong with it. Its a roomba i7+ 3 years old.
John Flannery - Replica
My Roomba will run until it hits the wall and then runs backwards. Help
beverly vernon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 221
Tutti i Tempi: 12,417
