Salta al contenuto principale
iRobot Roomba i7 Filter Replacement
  1. iRobot Roomba i7 Filter Replacement, Filter: passo 1, immagine 1 di 1
    • Flip the iRobot Roomba i7 so that the underside is facing upwards and the back is facing you.
    • On the left side at the back press the release button for the waste bin.
  2. iRobot Roomba i7 Filter Replacement: passo 2, immagine 1 di 1
    • Once the bin is removed, empty any waste into a trash can.
    • Be careful while emptying. Dust may escape and cause allergies.
  3. iRobot Roomba i7 Filter Replacement: passo 3, immagine 1 di 1
    • Locate the filter on the side of the bin.
    • Placing your fingers on the light grey area, pull the filter directly out of the bin.
    • If replacing the filter, follow these steps in reverse order.
  4. iRobot Roomba i7 Filter Replacement: passo 4, immagine 1 di 1
    • To clean the filter, tap it on the inside of a trash can.
    • Be careful not to shake dust everywhere; it may cause allergies.
    • Do not clean the filter with any type of liquid.
Conclusione
Altre 2 persone hanno completato questa guida.
3 Commenti
Question, please! I am unable to pull the filter out of the bin. It’s stuck. Any suggestions?
Christopher Liddle - Replica
This little filter barely does it's job. even after installing a brand new one, it'll be huffing and puffing dust everywhere it goes. My old Eufy 35C did a much better job than this much more expensive Roomba.
w.vries - Replica
I replaced the filter but it’s still not working.
Ashley Marie Vazquez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 171
Tutti i Tempi: 10,498
