Introduzione
The battery of the iRobot Roomba i6 model can wear down after time and require replacement. This guide will show you in 2 quick steps how to replace the battery.
Cosa ti serve
Using your PH2 size screwdriver, remove the edge sweeping brush.
Using your PH2 size screwdriver, remove the 5 screws highlighted in the 2nd picture.
These top two screws highlighted in orange will unscrew completely if you keep going so be sure to stop unscrewing them as soon as you feel resistance.
Lift the bottom cover straight up off of the Roomba from the two spots the arrows are pointing to.
Push the highlighted tab up while lifting the battery out of the Roomba.
To install the new battery, follow these instructions in reverse order.
