Introduzione
The iRobot Roomba e5 is a vacuum used by many families to keep their homes clean and free from debris on the floor. It is a great tool if you have animals and constantly experience hair or dirt throughout your house. However, sometimes the wheels on the vacuum might need replacement due to typical wear and tear or damage done by a curious family pet. In this guide you will find the steps it takes to replace both the right and left wheel, but before you do so you will need to purchase either the right or left wheel module depending on which you would like to replace, you can even replace both. You will also need a cross screwdriver to remove small screws that will need to be put somewhere safe and away from young children. Other than that, this replacement should be easy and simple.
Cosa ti serve
Flip the iRobot upside down
locate the edge sweeping brush which has a screw in the center.
Loosen the screw using a Phillips #1 screwdriver.
