Salta al contenuto principale
iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement
  1. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement, Home Base Vacuum Bag: passo 1, immagine 1 di 1
    • Open the vacuum bag container at the top of the home base.
  2. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: passo 2, immagine 1 di 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: passo 2, immagine 2 di 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: passo 2, immagine 3 di 3
    • Grab the grey tab at the top of the bag and lift the bag straight out of the home base.
Conclusione
Cal Poly, Team S18-G3, White Winter 2020 Membro di Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Membri
9 Guide realizzate
2 Commenti
what do you do if after you change the bag , the base says there is no bag? So I replaced the old bag after I pulled stuff out , still no change. now robot won’t work . On app it says end job stuck and all it did is move off base and turn around (after hit clean) help
shelleyandboys - Replica
Can we have a tear down of the base? The bag switch sometimes doesn't want to work properly. You can resolder a new switch or just solder a jumper so it always "senses" one. There's alot of screws, sensors, wires and a big motor. It helps to know where all the screws go.
ashimo0463 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,354
