Salta al contenuto principale
iRobot Roomba 980 Motherboard Replacement
Cosa ti serve
  1. iRobot Roomba 980 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
  2. iRobot Roomba 980 Motherboard Replacement: passo 2, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 2, immagine 2 di 2
    • Unscrew the back plate using a Phillips #1 screwdriver.
    • Carefully lift the panel up once the screws are removed.
  3. iRobot Roomba 980 Motherboard Replacement: passo 3, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 3, immagine 2 di 2
    • With both hands, grab the two black tabs on each end of the battery.
    • Pull the tabs upwards to remove the battery.
  4. iRobot Roomba 980 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 2
    • Remove the dust bin by pressing down on the rear button on the device.
    • Pull the bin towards you to remove it.
  5. iRobot Roomba 980 Motherboard Replacement: passo 5, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 5, immagine 2 di 2
    • Insert the opening tool in the back of the device under the wedge.
    • Slowly pry the plate loose and lift it from the device.
    • The face plate is only designed to be removed back to front.
  6. iRobot Roomba 980 Motherboard Replacement: passo 6, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 6, immagine 2 di 2
    • Loosen the screw holding the side brush in place, by using a Phillips #1 screwdriver
    • The screw is attached to the side brush and does not come out completely.
    • Lift the side brush.
  7. iRobot Roomba 980 Motherboard Replacement: passo 7, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the two 11.5mm screws holding down the bottom plate using a Phillips #1 screwdriver
    • Carefully lift the bottom plate.
  8. iRobot Roomba 980 Motherboard Replacement: passo 8, immagine 1 di 3 iRobot Roomba 980 Motherboard Replacement: passo 8, immagine 2 di 3 iRobot Roomba 980 Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove the four 15.8mm gold screws around the brush module using the Phillips #1 screwdriver.
    • Lift the brush module carefully using both hands.
  9. iRobot Roomba 980 Motherboard Replacement: passo 9, immagine 1 di 3 iRobot Roomba 980 Motherboard Replacement: passo 9, immagine 2 di 3 iRobot Roomba 980 Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove the three 15.8mm gold screws with a Phillips #1 screwdriver.
    • Lift the wheel module to remove it from the vacuum.
    • Remove the other wheel by repeating these steps.
  10. iRobot Roomba 980 Motherboard Replacement: passo 10, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the ten 6.1 mm silver screws using a Phillips #1 screwdriver.
    • Lift the bottom guard off the front sensor panel by pulling it upwards.
  11. iRobot Roomba 980 Motherboard Replacement: passo 11, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 11, immagine 2 di 2
    • Lift the two corner guards at the rear of the device by lifting and popping them out.
    • Pull the front sensor away slowly from the vacuum.
    • The cable connecting the front sensor to the Roomba is delicate, so proceed with caution.
  12. iRobot Roomba 980 Motherboard Replacement: passo 12, immagine 1 di 1
    • Flip the sensor over and use a Phillips #1 screwdriver to remove the two 3.8 mm silver screws that hold the sensors to the panel.
    • While the two 3.8mm screws look very similar to the 6.1mm screws, the two sizes are not interchangeable, so make sure not to mix the two sizes up when reassembling the Roomba.
    • Once removed, pull the panel away carefully.
  13. iRobot Roomba 980 Motherboard Replacement: passo 13, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 13, immagine 2 di 2
    • Remove the fourteen 6.6 mm black screws holding down the top plate using a Phillips #1 screwdriver.
    • Push the lip back towards the logo to remove two 6.6 mm black screws found under it using a Phillips #1 screwdriver.
  14. iRobot Roomba 980 Motherboard Replacement: passo 14, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 14, immagine 2 di 2
    • Lift the top plate slowly, being careful not to damage the vacuum components while exposing the motherboard.
  15. iRobot Roomba 980 Motherboard Replacement: passo 15, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 15, immagine 2 di 2
    • Remove the nine 6.4 mm silver screws holding the motherboard to the vacuum body and the clear plastic guard using a Phillips #1 screwdriver.
    • Carefully remove the connector-clips that are attached to the motherboard.
    • Some connectors will be difficult to remove.
  16. iRobot Roomba 980 Motherboard Replacement: passo 16, immagine 1 di 3 iRobot Roomba 980 Motherboard Replacement: passo 16, immagine 2 di 3 iRobot Roomba 980 Motherboard Replacement: passo 16, immagine 3 di 3
    • Using both hands, lift the motherboard connected to the camera away from the device's main motherboard.
    • Only lift the motherboard upwards to avoid bending the pins and causing further damage to the device's electronics.
    • Remove the black plastic guard that is placed in between the two computer boards
  17. iRobot Roomba 980 Motherboard Replacement: passo 17, immagine 1 di 2 iRobot Roomba 980 Motherboard Replacement: passo 17, immagine 2 di 2
    • Lift the main motherboard upward and off of the vacuum.
    • The screw inserts are holding it in place so it will have to be lifted evenly.
    • Remove the motherboard from your device.
Conclusione
Altre 21 persone hanno completato questa guida.
USF Tampa, Team S14-G2, Boczar Fall 2017 Membro di USF Tampa, Team S14-G2, Boczar Fall 2017
USFT-BOCZAR-F17S14G2
4 Membri
5 Guide realizzate
9 Commenti
Thank you for the replacement instructions & pictures…so helpful!
Any idea where I can purchase a roomba 980 motherboard?
LMSterling - Replica
Where can I purchase the roomba 980 motherboard?
Michael Goshorn - Replica
aliexpress my friend
hamilton.gazim -
you don’t need to take out the modules to take out the circuit board
LakeM0nst3r - Replica
If you find a rectangular rubber grommet left over when you’ve finished, it goes in a slot behind the dust bin and you can reinsert it from the outside just by removing the bin first.
James Turner - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 143
Tutti i Tempi: 17,147
