Salta al contenuto principale
iRobot Roomba 960 Debris Extractor Replacement
Cosa ti serve
  1. iRobot Roomba 960 Debris Extractor Replacement, Debris Extractor: passo 1, immagine 1 di 1
    • Turn the Roomba upside down and orient it so that the wheels are facing upwards and the dustbin is furthest from you.
  2. iRobot Roomba 960 Debris Extractor Replacement: passo 2, immagine 1 di 2 iRobot Roomba 960 Debris Extractor Replacement: passo 2, immagine 2 di 2
    • Pinch the two yellow tabs that are located near the dustbin towards each other to open the frame.
  3. iRobot Roomba 960 Debris Extractor Replacement: passo 3, immagine 1 di 1
    • Lift the frame to expose the two debris extractors.
  4. iRobot Roomba 960 Debris Extractor Replacement: passo 4, immagine 1 di 3 iRobot Roomba 960 Debris Extractor Replacement: passo 4, immagine 2 di 3 iRobot Roomba 960 Debris Extractor Replacement: passo 4, immagine 3 di 3
    • Carefully apply pressure to one side of the first debris extractor to release it. Lift to remove.
    • Do the same to the second debris extractor.
Conclusione
USF Tampa, Team 16-3, Blackwell Spring 2017 Membro di USF Tampa, Team 16-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,415
