Salta al contenuto principale
iRobot Roomba 891 Extractor Assembly Replacement
Cosa ti serve
  1. iRobot Roomba 891 Extractor Assembly Replacement, Battery: passo 1, immagine 1 di 2 iRobot Roomba 891 Extractor Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Extractor Assembly Replacement: passo 2, immagine 1 di 1
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Extractor Assembly Replacement: passo 3, immagine 1 di 3 iRobot Roomba 891 Extractor Assembly Replacement: passo 3, immagine 2 di 3 iRobot Roomba 891 Extractor Assembly Replacement: passo 3, immagine 3 di 3
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
  4. iRobot Roomba 891 Extractor Assembly Replacement, Side Brush: passo 4, immagine 1 di 2 iRobot Roomba 891 Extractor Assembly Replacement, Side Brush: passo 4, immagine 2 di 2
    • Remove the 7.5mm flat head #4 screw from center of the side brush.
  5. iRobot Roomba 891 Extractor Assembly Replacement: passo 5, immagine 1 di 1
    • Gently pull the side brush off of the motor hub.
  6. iRobot Roomba 891 Extractor Assembly Replacement, Extractor Assembly: passo 6, immagine 1 di 1
    • Remove the dustbin assembly from the Roomba.
  7. iRobot Roomba 891 Extractor Assembly Replacement: passo 7, immagine 1 di 3 iRobot Roomba 891 Extractor Assembly Replacement: passo 7, immagine 2 di 3 iRobot Roomba 891 Extractor Assembly Replacement: passo 7, immagine 3 di 3
    • Unscrew the 2 phillips #2 11mm screws from roomba.
    • These captive screws will remain in the bottom cover after being loosened.
  8. iRobot Roomba 891 Extractor Assembly Replacement: passo 8, immagine 1 di 2 iRobot Roomba 891 Extractor Assembly Replacement: passo 8, immagine 2 di 2
    • Lift the yellow tabs and lift the red cover from the extractor assembly.
  9. iRobot Roomba 891 Extractor Assembly Replacement: passo 9, immagine 1 di 1
    • Remove the rollers from the assembly by lifting it out from right side.
  10. iRobot Roomba 891 Extractor Assembly Replacement: passo 10, immagine 1 di 2 iRobot Roomba 891 Extractor Assembly Replacement: passo 10, immagine 2 di 2
    • Close the cover and remove the four 11mm Phillips #00 screws from the assembly.
  11. iRobot Roomba 891 Extractor Assembly Replacement: passo 11, immagine 1 di 1
    • Grasp the center of the assembly and remove from the roomba.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 752
