Salta al contenuto principale
iRobot Roomba 891 Drive Wheels Replacement
Cosa ti serve
  1. iRobot Roomba 891 Drive Wheels Replacement, Battery: passo 1, immagine 1 di 2 iRobot Roomba 891 Drive Wheels Replacement, Battery: passo 1, immagine 2 di 2
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Drive Wheels Replacement: passo 2, immagine 1 di 1
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Drive Wheels Replacement: passo 3, immagine 1 di 3 iRobot Roomba 891 Drive Wheels Replacement: passo 3, immagine 2 di 3 iRobot Roomba 891 Drive Wheels Replacement: passo 3, immagine 3 di 3
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
  4. iRobot Roomba 891 Drive Wheels Replacement, Side Brush: passo 4, immagine 1 di 2 iRobot Roomba 891 Drive Wheels Replacement, Side Brush: passo 4, immagine 2 di 2
    • Remove the 7.5mm flat head #4 screw from center of the side brush.
  5. iRobot Roomba 891 Drive Wheels Replacement: passo 5, immagine 1 di 1
    • Gently pull the side brush off of the motor hub.
  6. iRobot Roomba 891 Drive Wheels Replacement, Drive Wheels: passo 6, immagine 1 di 1
    • Remove dustbin assembly from the Roomba.
  7. iRobot Roomba 891 Drive Wheels Replacement: passo 7, immagine 1 di 3 iRobot Roomba 891 Drive Wheels Replacement: passo 7, immagine 2 di 3 iRobot Roomba 891 Drive Wheels Replacement: passo 7, immagine 3 di 3
    • Remove 2 Phillips #2 11mm screws from the bottom cover.
    • These captive crews are designed to stay in the bottom cover.
    • Remove the bottom cover.
  8. iRobot Roomba 891 Drive Wheels Replacement: passo 8, immagine 1 di 3 iRobot Roomba 891 Drive Wheels Replacement: passo 8, immagine 2 di 3 iRobot Roomba 891 Drive Wheels Replacement: passo 8, immagine 3 di 3
    • Unscrew three Phillips #00 gold 11mm screws from the drive module.
    • Both modules have the same number of screws and are mirror images of each other.
    • Left module is shown in the photos.
  9. iRobot Roomba 891 Drive Wheels Replacement: passo 9, immagine 1 di 1
    • Grasp wheel module and remove from roomba.
    • Inspect housing for debris.
Conclusione
Un commento
justin i added the word captive to the steps where the screws stayed in place
thomas Wilson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 512
