Salta al contenuto principale
iRobot Roomba 891 Battery Replacement
Cosa ti serve
  1. iRobot Roomba 891 Battery Replacement, Battery: passo 1, immagine 1 di 2 iRobot Roomba 891 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Battery Replacement: passo 2, immagine 1 di 1
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Battery Replacement: passo 3, immagine 1 di 3 iRobot Roomba 891 Battery Replacement: passo 3, immagine 2 di 3 iRobot Roomba 891 Battery Replacement: passo 3, immagine 3 di 3
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
justin i added a push pin to step 1
thomas Wilson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 13
Tutti i Tempi: 788
