Salta al contenuto principale
iRobot Roomba 890 Charging Contacts Replacement
Cosa ti serve
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: passo 1, immagine 1 di 2 iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: passo 1, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: passo 2, immagine 1 di 1
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: passo 3, immagine 1 di 1
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: passo 4, immagine 1 di 2 iRobot Roomba 890 Charging Contacts Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: passo 5, immagine 1 di 2 iRobot Roomba 890 Charging Contacts Replacement: passo 5, immagine 2 di 2
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: passo 6, immagine 1 di 2 iRobot Roomba 890 Charging Contacts Replacement: passo 6, immagine 2 di 2
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: passo 7, immagine 1 di 3 iRobot Roomba 890 Charging Contacts Replacement: passo 7, immagine 2 di 3 iRobot Roomba 890 Charging Contacts Replacement: passo 7, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: passo 8, immagine 1 di 2 iRobot Roomba 890 Charging Contacts Replacement: passo 8, immagine 2 di 2
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: passo 9, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: passo 10, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: passo 11, immagine 1 di 1
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 157
Tutti i Tempi: 4,163
