Salta al contenuto principale
iRobot Roomba 870 Side Brush Motor Replacement
Cosa ti serve
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: passo 1, immagine 1 di 3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: passo 1, immagine 2 di 3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: passo 1, immagine 3 di 3
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: passo 2, immagine 1 di 2 iRobot Roomba 870 Side Brush Motor Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: passo 3, immagine 1 di 2 iRobot Roomba 870 Side Brush Motor Replacement: passo 3, immagine 2 di 2
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: passo 4, immagine 1 di 3 iRobot Roomba 870 Side Brush Motor Replacement: passo 4, immagine 2 di 3 iRobot Roomba 870 Side Brush Motor Replacement: passo 4, immagine 3 di 3
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: passo 5, immagine 1 di 3 iRobot Roomba 870 Side Brush Motor Replacement: passo 5, immagine 2 di 3 iRobot Roomba 870 Side Brush Motor Replacement: passo 5, immagine 3 di 3
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: passo 6, immagine 1 di 3 iRobot Roomba 870 Side Brush Motor Replacement: passo 6, immagine 2 di 3 iRobot Roomba 870 Side Brush Motor Replacement: passo 6, immagine 3 di 3
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S14-G3, Banghart Spring 2017 Membro di Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,676
