Salta al contenuto principale
iRobot Roomba 860 Debris Extractor Cleaning / Replacement
Cosa ti serve
  1. iRobot Roomba 860 Debris Extractor Cleaning / Replacement, Debris Extractors: passo 1, immagine 1 di 2 iRobot Roomba 860 Debris Extractor Cleaning / Replacement, Debris Extractors: passo 1, immagine 2 di 2
    • To remove the debris extractor, first begin by removing and emptying the trash bin.
    • Push down and pull out on the silver button located on the top of the Roomba in the back.
    • The trash bin should then slide out.
  2. iRobot Roomba 860 Debris Extractor Cleaning / Replacement: passo 2, immagine 1 di 2 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: passo 2, immagine 2 di 2
    • With the Roomba upside down, locate the two yellow buttons by the extractor.
    • To open the flap holding the extractos in place, pinch the two yellow buttons together towards the center and pull up on the flap at the same time
  3. iRobot Roomba 860 Debris Extractor Cleaning / Replacement: passo 3, immagine 1 di 3 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: passo 3, immagine 2 di 3 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: passo 3, immagine 3 di 3
    • Once the flap is open, grab the yellow end of the dark gray extractor and pull up slightly.
    • After lifting it up about an inch, pull it out towards one of the side wheels.
    • The extractor should slide out with ease. Repeat the same procedure for the light gray debris extractor.
Conclusione
Altre 2 persone hanno completato questa guida.
Ryan Murphy
Membro da: 03/02/17
446 Reputazione
4 Guide realizzate
USF Tampa, Team S13-G5, Cagle Spring 2017 Membro di USF Tampa, Team S13-G5, Cagle Spring 2017
USFT-CAGLE-S17S13G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,444
