Salta al contenuto principale
iRobot Roomba 770 Side Brush Motor Replacement
Cosa ti serve
  1. iRobot Roomba 770 Side Brush Motor Replacement, Battery: passo 1, immagine 1 di 2 iRobot Roomba 770 Side Brush Motor Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Side Brush Motor Replacement: passo 2, immagine 1 di 2 iRobot Roomba 770 Side Brush Motor Replacement: passo 2, immagine 2 di 2
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
  3. iRobot Roomba 770 Side Brush Motor Replacement, Side Brush Motor: passo 3, immagine 1 di 1
    • Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
    • Remove the brush by pulling upwards.
    • Do not lean directly over the brush when attempting to remove. Removing the brush requires a firm pull and may release suddenly.
  4. iRobot Roomba 770 Side Brush Motor Replacement: passo 4, immagine 1 di 2 iRobot Roomba 770 Side Brush Motor Replacement: passo 4, immagine 2 di 2
    • Using the J1 Philips Screwdriver, remove the two 15.5 mm screws located on the bottom of the plate covering the bottom of the roomba.
    • Lift upwards to remove the bottom plate.
  5. iRobot Roomba 770 Side Brush Motor Replacement: passo 5, immagine 1 di 2 iRobot Roomba 770 Side Brush Motor Replacement: passo 5, immagine 2 di 2
    • Using the J1 Philips Screwdriver, remove the two gold 15.5 mm screws located on the blue plastic module the side brush had previously been attached too.
    • Lift the blue module upwards. The module contains the motor for the side brush.
Conclusione
Ashley Woods
Membro da: 10/06/16
347 Reputazione
1 Guida realizzata
Cal Poly, Team 15-3, Livingston Fall 2016 Membro di Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,670
