Introduzione
These wheels control the main movement of the device. Since it is one of the main parts used, the tires of the wheel may get worn, debris may get caught inside, or the wheel may just need to be replaced from overuse.
Cosa ti serve
Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
Remove the plastic plate from the battery box.
Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
Remove the brush by pulling upwards.
Locate the three 15.5 mm screws surrounding each wheel. Use a J1 Philips screw driver to remove these.
Use your J1 Philips screwdriver to remove these screws.
Altre 4 persone hanno completato questa guida.
