Salta al contenuto principale
iRobot Roomba 770 Brush Replacement
  1. iRobot Roomba 770 Brush Replacement, Brush: passo 1, immagine 1 di 1
    • Orient the roomba so it is upside down and the dust tray is closest to you.
  2. iRobot Roomba 770 Brush Replacement: passo 2, immagine 1 di 2 iRobot Roomba 770 Brush Replacement: passo 2, immagine 2 di 2
    • Locate the two yellow tabs on the screen that covers the brushes.
    • Push inwards on the yellow tabs while simultaneously pulling upwards on the attached grey cage.
  3. iRobot Roomba 770 Brush Replacement: passo 3, immagine 1 di 3 iRobot Roomba 770 Brush Replacement: passo 3, immagine 2 di 3 iRobot Roomba 770 Brush Replacement: passo 3, immagine 3 di 3
    • Grab the right side of the larger brush that is located near the yellow cap. Pull upwards and to the right to remove the brush.
    • Repeat the same steps with the smaller brush.
  4. iRobot Roomba 770 Brush Replacement: passo 4, immagine 1 di 2 iRobot Roomba 770 Brush Replacement: passo 4, immagine 2 di 2
    • Orient the brush so the yellow tab is on the right hand side.
    • Pull the yellow tab to the right to remove.
    • Remove any debris, paying attention to the ends as well as the brush itself.
    • Replace any damaged brushes.
Conclusione
Cal Poly, Team 15-3, Livingston Fall 2016 Membro di Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 Membri
5 Guide realizzate
Un commento
My roomba starts and moves a foot or so and then stops. I have cleaned it entirely, the battery is fine and the wheels are clean. Anyone have a suggestion
Mary Ann Dyer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,334
