Salta al contenuto principale
iRobot Roomba 690 Drive Wheels Replacement
Cosa ti serve
  1. iRobot Roomba 690 Drive Wheels Replacement, Spinning Brush: passo 1, immagine 1 di 1
    • Place the Roomba upside down so that the wheels and brushes are facing upward.
  2. iRobot Roomba 690 Drive Wheels Replacement: passo 2, immagine 1 di 3 iRobot Roomba 690 Drive Wheels Replacement: passo 2, immagine 2 di 3 iRobot Roomba 690 Drive Wheels Replacement: passo 2, immagine 3 di 3
    • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
    • Remove the spinning brush from the vacuum.
  3. iRobot Roomba 690 Drive Wheels Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
    • They are labeled with triangular arrows next to them on the cover.
  4. iRobot Roomba 690 Drive Wheels Replacement: passo 4, immagine 1 di 1
    • Lift the bottom cover up from the rest of the Roomba.
  5. iRobot Roomba 690 Drive Wheels Replacement: passo 5, immagine 1 di 3 iRobot Roomba 690 Drive Wheels Replacement: passo 5, immagine 2 di 3 iRobot Roomba 690 Drive Wheels Replacement: passo 5, immagine 3 di 3
    • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
  6. iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: passo 6, immagine 1 di 2 iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: passo 6, immagine 2 di 2
    • Each drive wheel is labeled left and right.
    • Remove three 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
    • Remove the drive wheels from the vacuum.
Conclusione
John Galvin
Membro da: 03/23/22
584 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 21
Tutti i Tempi: 430
