Salta al contenuto principale
iRobot Roomba 655 Pet Series Front Caster Wheel Replacement
Cosa ti serve
  1. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Side Brush: passo 1, immagine 1 di 2 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Side Brush: passo 1, immagine 2 di 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Back Panel: passo 2, immagine 1 di 2 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Back Panel: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: passo 3, immagine 1 di 3 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: passo 3, immagine 2 di 3 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: passo 3, immagine 3 di 3
    • Turn the Roomba upside down, so that the vacuum and wheels are facing the ceiling.
    • Hold the caster wheel housing steady and insert the plastic spudger under the wheel housing.
    • Apply some force to pry the caster wheel straight up out of the device, and remove the caster wheel housing from the Roomba.
  4. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing Wheel From Rotating Housing: passo 4, immagine 1 di 2 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing Wheel From Rotating Housing: passo 4, immagine 2 di 2
    • Firmly hold the caster wheel housing, and remove the caster wheel from its setting.
    • Clean the caster wheel with soap and water.
    • Once the caster wheel is clean and thoroughly dried, repeat the process in reverse order to reinstall the caster wheel back to the Roomba.
Conclusione
To reassemble the robot, follow these instructions in reverse order.
Altre 3 persone hanno completato questa guida.
Rhett
Membro da: 01/22/15
1.329 Reputazione
7 Guide realizzate
Cal Poly, Team 21-20, Maness Winter 2015 Membro di Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 5,887
