Salta al contenuto principale
iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal
Cosa ti serve
  1. iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Side Brush: passo 1, immagine 1 di 2 iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Side Brush: passo 1, immagine 2 di 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Back Panel: passo 2, immagine 1 di 2 iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Back Panel: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
Conclusione
Matt Davis
Membro da: 01/22/15
1.642 Reputazione
7 Guide realizzate
Cal Poly, Team 21-20, Maness Winter 2015 Membro di Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,588
