Salta al contenuto principale
iRobot Roomba 655 Pet Series Front Bumper Replacement
Cosa ti serve
  1. iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: passo 1, immagine 1 di 2 iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: passo 1, immagine 2 di 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  2. iRobot Roomba 655 Pet Series Front Bumper  Replacement: passo 2, immagine 1 di 3 iRobot Roomba 655 Pet Series Front Bumper  Replacement: passo 2, immagine 2 di 3 iRobot Roomba 655 Pet Series Front Bumper  Replacement: passo 2, immagine 3 di 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
Conclusione
Rhett
Membro da: 01/22/15
1.329 Reputazione
7 Guide realizzate
Cal Poly, Team 21-20, Maness Winter 2015 Membro di Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,320
