Salta al contenuto principale
iRobot Roomba 655 Pet Series Drive Wheels Replacement
Cosa ti serve
  1. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: passo 1, immagine 1 di 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: passo 1, immagine 2 di 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: passo 2, immagine 1 di 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: passo 3, immagine 1 di 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: passo 3, immagine 2 di 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: passo 3, immagine 3 di 3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: passo 4, immagine 1 di 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: passo 4, immagine 2 di 2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: passo 5, immagine 1 di 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: passo 5, immagine 2 di 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: passo 5, immagine 3 di 3
    • Remove the three screws with your Phillips head #1, holding the drive wheels in place
    • These three screws will stay in place and won't come out of the plastic
  6. iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 6, immagine 1 di 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 6, immagine 2 di 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 6, immagine 3 di 3
    • Unscrew the actual wheel from the blue plastic holder
    • Pull apart the blue holder to completely remove the wheel
  7. iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 7, immagine 1 di 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 7, immagine 2 di 2
    • To go further into the holder to access the programming chips you can unscrew these compartments
Conclusione
Rhett
Membro da: 01/22/15
1.329 Reputazione
7 Guide realizzate
Cal Poly, Team 21-20, Maness Winter 2015 Membro di Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,249
