Salta al contenuto principale
iRobot Roomba 650 Caster Wheel Replacement
Cosa ti serve
  1. iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: passo 1, immagine 1 di 2 iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: passo 1, immagine 2 di 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: passo 2, immagine 1 di 2 iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: passo 2, immagine 2 di 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Caster Wheel Replacement, Caster Wheel: passo 3, immagine 1 di 1
    • Begin by pulling on the caster wheel. It should pop out of its housing fairly easily.
  4. iRobot Roomba 650 Caster Wheel Replacement: passo 4, immagine 1 di 2 iRobot Roomba 650 Caster Wheel Replacement: passo 4, immagine 2 di 2
    • Once caster wheel is off the Roomba, push on the wheel so that it slides out of the groves it sits in.
Conclusione
Altre 2 persone hanno completato questa guida.
Alex Schnorr
Membro da: 01/22/15
628 Reputazione
3 Guide realizzate
Cal Poly, Team 19-7, Maness Winter 2015 Membro di Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Membri
6 Guide realizzate
3 Commenti
Alternate instructions.
1. skip steps 1 and 2. you don't need to take the panel off to remove the caster wheel.
2. follow steps 3 and 4.
Matt Johnson - Replica
Worked for my 690 as well.
Luke Oliver - Replica
Hi, my caster wheel drops out easiy from the groves… a bit like the groves are worn out already and are no longer able to hold the wheel metal spoke in place. I would like to know if this can be fixed without resorting to buying a new wheel? (Reduce, Reuse, Recycle) Please help?
Rykel Lim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,149
