Salta al contenuto principale
iRobot Roomba 630 Top Bumper Infrared Sensor Replacement
Cosa ti serve
  1. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement, Front Sensor: passo 1, immagine 1 di 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement, Front Sensor: passo 1, immagine 2 di 2
    • Press the bin button and pull the bin out.
  2. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 2, immagine 1 di 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 2, immagine 2 di 2
    • FIip the device over and unscrew the side brush screw using the Phillips #2 screwdriver.
  3. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 3, immagine 1 di 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 3, immagine 2 di 2
    • Unscrew the (4) four back plate screws using the Phillips #2 screwdriver.
    • Lift the back plate off of the device.
  4. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 4, immagine 1 di 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 4, immagine 2 di 2
    • Unscrew the screws on the bottom of the front bumper.
  5. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 5, immagine 1 di 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 5, immagine 2 di 2
    • Flip the device over and lift the front bumper up and off.
    • Lift with care so the sensor wires aren't damaged.
  6. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 6, immagine 1 di 2 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 6, immagine 2 di 2
    • Flip the Roomba back over and unscrew the 2 screws that connect the sensor to the bumper.
  7. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 7, immagine 1 di 3 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 7, immagine 2 di 3 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 7, immagine 3 di 3
    • Flip Roomba back over and pry the top cover off.
    • Unscrew the screws to the top plate and lift off.
  8. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 8, immagine 1 di 3 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 8, immagine 2 di 3 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers or another tool to push up on the insert while gently pulling the sensor out by its wires.
    • Remove the sensor.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S5-G3, Walkup Fall 2017 Membro di USF Tampa, Team S5-G3, Walkup Fall 2017
USFT-WALKUP-F17S5G3
4 Membri
7 Guide realizzate
4 Commenti
Exact same instructions for a Roomba 690. Great guide and much cheaper than sending it in for out of warranty repair at $135 bucks!!!
Jeff Brockway - Replica
Outstanding! I would only add to note position of the 12 top plate screws as they are removed since 3 are smaller/shorter (although not noticeably so) and need to be returned to their exact location. I would not call this difficult. Simply tedious. Thank you very much for the instrucitons.
Linda Marsh - Replica
Thanks for this. Roomba wanted me to send my unit in for repairs costing $130. I bought a replacement Rcon at eBay for $10. Turned out, as others have posted, the red wire was broken! That’s on Roomba!! Works like new, will repair the red wire, and save the rcon for future use.
natenaybore - Replica
This is very helpful! Thank you. In my case, all the 3 wires were thorn from the sensor head. I could resolver them but I can’t tell which is which. Can someone post where the 3 wires connect in the sensor head? There are 3 leads coming out of the sensor head but no insulation left on them so I can match with the correct wire. Much appreciated!
GandaFix - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 65
Tutti i Tempi: 9,618
