Introduzione
This guide is useful for replacing a dead battery or a battery that cannot be recharged through the dock for some reason. This guide is pretty simple can be done in 3 steps, and won't break anything important
Cosa ti serve
Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
Altre 5 persone hanno completato questa guida.
3Commenti sulla guida
Pls, can i charge the roomba directly, because the base is not working??
Yes I think so, mine can
Je dois chznger ma batterie qui est hs, mais les vis st morts, comment faire pour dĂ©monter le cache sans rien casser... sinon est ce que le cache et les vis peuvent ĂȘtre refournis par le sav?
