Salta al contenuto principale
iRobot Roomba 560 Side Sweeper Replacement
Cosa ti serve
  1. iRobot Roomba 560 Side Sweeper Replacement, Side Sweeper: passo 1, immagine 1 di 1
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. iRobot Roomba 560 Side Sweeper Replacement: passo 2, immagine 1 di 1
    • Lift the yellow side sweeper, removing it from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 1-22, Maness Fall 2015 Membro di Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Membri
14 Guide realizzate
2 Commenti
I need to replace the part on the bottom where the side sweeper screws in. The threads are stripped, I’m guessing, and screw won’t stay in.
Candy Schnurr - Replica
put some hot glue or melt some plastic in the hole before screwing it. you should get the threads back when you unscrew it
Nicolas Sicard -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,697
