Salta al contenuto principale
iRobot Roomba 560 Fan Replacement
Cosa ti serve
  1. iRobot Roomba 560 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
  2. iRobot Roomba 560 Fan Replacement: passo 2, immagine 1 di 2 iRobot Roomba 560 Fan Replacement: passo 2, immagine 2 di 2
    • Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
    • Remove the top of the vacuum bin by pulling it straight up.
    • The bin is composed of two parts (the clear top casing and the red bottom filter). To avoid a mess, be careful to not let these two pieces detach, unless over a trash bin.
  3. iRobot Roomba 560 Fan Replacement: passo 3, immagine 1 di 3 iRobot Roomba 560 Fan Replacement: passo 3, immagine 2 di 3 iRobot Roomba 560 Fan Replacement: passo 3, immagine 3 di 3
    • Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
    • Remove the casing that surrounds the fan by pulling it straight up.
    • The casing is composed of 2 parts (the large top casing, and a small air filter). If these parts detach, they are very easy to put back together. Do not lose the air filter.
  4. iRobot Roomba 560 Fan Replacement: passo 4, immagine 1 di 3 iRobot Roomba 560 Fan Replacement: passo 4, immagine 2 di 3 iRobot Roomba 560 Fan Replacement: passo 4, immagine 3 di 3
    • Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
    • Remove the casing from the fan and battery component by pulling it straight up.
  5. iRobot Roomba 560 Fan Replacement: passo 5, immagine 1 di 1
    • Remove the small black button from the top of the battery.
    • Save the spring and the button cover. The remainder of the fan assembly (yellow motor and the black housing) will need to be replaced as a unit.
Conclusione
Altre 2 persone hanno completato questa guida.
TJ Tamura
Membro da: 10/01/15
277 Reputazione
1 Guida realizzata
Cal Poly, Team 1-22, Maness Fall 2015 Membro di Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 44
Tutti i Tempi: 4,374
