Salta al contenuto principale
Introduzione
This guide explains how to quickly remove the side brush from your Roomba in order to either replace it or to further disassemble the device.
Parti
Nessuna parte specificata.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
Conclusione
Aaron Jacobs
Membro da: 31/01/2014
534 Reputazione
4 Guide realizzate
Cal Poly, Team 13-14, Regan Winter 2014 Membro di Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Membri
13 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 261
