Salta al contenuto principale
iRobot Roomba 551 Faceplate Replacement
Cosa ti serve
  1. iRobot Roomba 551 Faceplate Replacement, Side Brush: passo 1, immagine 1 di 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Faceplate Replacement: passo 2, immagine 1 di 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Faceplate Replacement: passo 3, immagine 1 di 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Faceplate Replacement, Bottom Plate: passo 4, immagine 1 di 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Faceplate Replacement: passo 5, immagine 1 di 2 iRobot Roomba 551 Faceplate Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Faceplate Replacement: passo 6, immagine 1 di 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Faceplate Replacement, iRobot Roomba 551 Dirt Bin Replacement: passo 7, immagine 1 di 1
    • Push on the dirt bin release button, and pull gently.
  8. iRobot Roomba 551 Faceplate Replacement, Bumper: passo 8, immagine 1 di 3 iRobot Roomba 551 Faceplate Replacement, Bumper: passo 8, immagine 2 di 3 iRobot Roomba 551 Faceplate Replacement, Bumper: passo 8, immagine 3 di 3
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  9. iRobot Roomba 551 Faceplate Replacement: passo 9, immagine 1 di 1
    • Lift the bottom cover and set it to the side.
  10. iRobot Roomba 551 Faceplate Replacement: passo 10, immagine 1 di 2 iRobot Roomba 551 Faceplate Replacement: passo 10, immagine 2 di 2
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
  11. iRobot Roomba 551 Faceplate Replacement, Faceplate: passo 11, immagine 1 di 3 iRobot Roomba 551 Faceplate Replacement, Faceplate: passo 11, immagine 2 di 3 iRobot Roomba 551 Faceplate Replacement, Faceplate: passo 11, immagine 3 di 3
    • Pull up on the front of the faceplate until the friction locks pop out of place.
  12. iRobot Roomba 551 Faceplate Replacement: passo 12, immagine 1 di 2 iRobot Roomba 551 Faceplate Replacement: passo 12, immagine 2 di 2
    • Continue around the outside of the Roomba, pulling up on the faceplate to free all of the outer friction locks.
  13. iRobot Roomba 551 Faceplate Replacement: passo 13, immagine 1 di 2 iRobot Roomba 551 Faceplate Replacement: passo 13, immagine 2 di 2
    • Grab the faceplate by the outer edge and pull upwards, freeing the center friction locks in the process.
Conclusione
Aaron Jacobs
Membro da: 01/31/14
540 Reputazione
4 Guide realizzate
Cal Poly, Team 13-14, Regan Winter 2014 Membro di Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Membri
19 Guide realizzate
Un commento
If all you need off is the faceplate, you can start at step 11 and skip the 1-10. The bottom and bumper assemblies seem completely unrelated to the faceplate. I removed the dirt bin and started lifiting at the back edge, then worked around the faceplate and it just popped off with no damage.
There are 4 long friction tabs around the circumference, and no tabs at the center. Once the outer friction tabs are free, the center circle of the faceplate comes off cleanly, leaving the display panel, control buttons and the chrome-ish ring. Under the 'IR' in the IRobot logo on the faceplate is the SCI port, more plastic and a number of screws to get to the motherboard.
David Forrest - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,055
