Salta al contenuto principale
iRobot Roomba 551 Brushes Replacement
Cosa ti serve
  1. iRobot Roomba 551 Brushes Replacement, Side Brush: passo 1, immagine 1 di 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Brushes Replacement: passo 2, immagine 1 di 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brushes Replacement: passo 3, immagine 1 di 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brushes Replacement, Bottom Plate: passo 4, immagine 1 di 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brushes Replacement: passo 5, immagine 1 di 2 iRobot Roomba 551 Brushes Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brushes Replacement: passo 6, immagine 1 di 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brushes Replacement, Brushes: passo 7, immagine 1 di 2 iRobot Roomba 551 Brushes Replacement, Brushes: passo 7, immagine 2 di 2
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
  8. iRobot Roomba 551 Brushes Replacement: passo 8, immagine 1 di 3 iRobot Roomba 551 Brushes Replacement: passo 8, immagine 2 di 3 iRobot Roomba 551 Brushes Replacement: passo 8, immagine 3 di 3
    • Grab each brush and lift upwards to remove.
Conclusione
John McTigue
Membro da: 01/31/14
331 Reputazione
3 Guide realizzate
Cal Poly, Team 13-14, Regan Winter 2014 Membro di Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Membri
19 Guide realizzate
2 Commenti
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Replica
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 86
Ultimi 30 Giorni: 376
Tutti i Tempi: 7,242
