Salta al contenuto principale
iRobot Roomba 551 Battery Replacement
Cosa ti serve
  1. iRobot Roomba 551  Battery Replacement, Side Brush: passo 1, immagine 1 di 1
    • Place your Roomba upside-down on a hard surface.
    If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
    David Forrest - Replica
  2. iRobot Roomba 551  Battery Replacement: passo 2, immagine 1 di 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551  Battery Replacement: passo 3, immagine 1 di 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: passo 4, immagine 1 di 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551  Battery Replacement: passo 5, immagine 1 di 2 iRobot Roomba 551  Battery Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551  Battery Replacement: passo 6, immagine 1 di 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551  Battery Replacement, Battery: passo 7, immagine 1 di 2 iRobot Roomba 551  Battery Replacement, Battery: passo 7, immagine 2 di 2
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 13-14, Regan Winter 2014 Membro di Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Membri
19 Guide realizzate
Un commento
Thank you Deborah!
James - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 147
Tutti i Tempi: 9,593
