Salta al contenuto principale
iRobot Roomba 4160 Brush Replacement
  1. iRobot Roomba 4160 Brush Replacement, Brush Guard: passo 1, immagine 1 di 1
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Replacement: passo 2, immagine 1 di 1
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Replacement: passo 3, immagine 1 di 2 iRobot Roomba 4160 Brush Replacement: passo 3, immagine 2 di 2
    • After the guard hinges up, lift the guard up and away from the Roomba.
  4. iRobot Roomba 4160 Brush Replacement, Brush: passo 4, immagine 1 di 1
    • Remove the wire brush by grabbing it by the yellow plastic part of the brush.
    • Pull the brush upwards until it comes out.
  5. iRobot Roomba 4160 Brush Replacement: passo 5, immagine 1 di 2 iRobot Roomba 4160 Brush Replacement: passo 5, immagine 2 di 2
    • Remove the rubber spinning brush by grabbing it by the rubber part on both ends.
    • Pull the brush upwards until it dislodges.
Conclusione
Altre 2 persone hanno completato questa guida.
noah falck
Membro da: 04/07/14
104 Reputazione
1 Guida realizzata
Cal Poly, Team 6-4, Forte Spring 2014 Membro di Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 297
