Salta al contenuto principale
iRobot Roomba 4160 Battery Replacement
  1. iRobot Roomba 4160 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the Roomba is turned off to avoid an electric shock.
    • Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
    • Do not attempt to open up the yellow battery pack. You may get shocked or burned by the battery acid.
  2. iRobot Roomba 4160 Battery Replacement: passo 2, immagine 1 di 2 iRobot Roomba 4160 Battery Replacement: passo 2, immagine 2 di 2
    • Identify the yellow plastic rectangular battery, directly to the right of the spinning brush.
    • Place your index fingers on the small rectangular plastic tabs on both sides of the battery. Push the tabs in until the battery comes loose.
    • Pull battery out using your fingers.
Conclusione
To re-install battery, follow these instructions in reverse order.
Cal Poly, Team 6-4, Forte Spring 2014 Membro di Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,010
