Salta al contenuto principale
iRobot Roomba 4100 Main Brush Replacement
  1. iRobot Roomba 4100 Main Brush Replacement, Brush Guard: passo 1, immagine 1 di 1
    • Lay the Roomba upside down on a flat surface with the blue strip away from you.
  2. iRobot Roomba 4100 Main Brush Replacement: passo 2, immagine 1 di 2 iRobot Roomba 4100 Main Brush Replacement: passo 2, immagine 2 di 2
    • Use your index fingers to pull the yellow tabs towards you.
    • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • For reassembly, make sure to push in the brush guard until it clicks into place.
  3. iRobot Roomba 4100 Main Brush Replacement: passo 3, immagine 1 di 1
    • Pull back the brush guard to unhook it from the latches.
    • Remove the brush guard by lifting it up and out of the Roomba.
    • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
  4. iRobot Roomba 4100 Main Brush Replacement, Main Brush: passo 4, immagine 1 di 1
    • Set the brush guard aside.
    • The main brush is the bristly one that is closest to the blue strip.
  5. iRobot Roomba 4100 Main Brush Replacement: passo 5, immagine 1 di 2 iRobot Roomba 4100 Main Brush Replacement: passo 5, immagine 2 di 2
    • Remove the main brush by grabbing it and pulling it up and out of the Roomba.
    • For reassembly, orient the Roomba with the battery closest to you:
    • First, insert the black end of the main brush into the black square opening on the right side.
    • Second, lay the main brush back into place.
Conclusione
Samantha Barrett
Membro da: 01/13/14
501 Reputazione
5 Guide realizzate
Cal Poly, Team 17-5, Forte Winter 2014 Membro di Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 915
