Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If the filter on your iRobot Braava Jet 240 needs to be replaced, follow this guide.
The filter is located between the tank cover and the tank. The filter catches any residue that is in the water, ensuring that the iRobot Braava Jet 240 only sprays clean water. If the filter collects too much dirt, it needs to be removed and cleaned. The filter could also tear, in which case it should be replaced.
  1. Turn the device off.
    • Turn the device off.
  2. Use your fingers to gently pop out the battery. Use your fingers to gently pop out the battery.
    • Use your fingers to gently pop out the battery.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Lift the handle to access the filter. Lift the handle to access the filter.
    • Lift the handle to access the filter.
  5. Pull up the filter cover. Pull up the filter cover. Pull up the filter cover.
    • Pull up the filter cover.
  6. Insert your finger into the filter and pull it up to remove it from the device. Insert your finger into the filter and pull it up to remove it from the device. Insert your finger into the filter and pull it up to remove it from the device.
    • Insert your finger into the filter and pull it up to remove it from the device.
Conclusione
Claire Franz
Membro da: 10/02/2020
1.355 Reputazione
7 Guide realizzate
Cal Poly, Team S22-G2, Regan Winter 2020 Membro di Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 276
