Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If your iRobot Braava Jet 240 battery does not charge when it is placed in the charging adaptor and plugged into the wall, use this guide to replace the battery. A working battery provides power to the robot. Over time, recharging causes the battery to lose the ability to hold charge, meaning it will need to be replaced.
It is important to remove the battery before replacing other parts to ensure the robot does not turn on accidentally. Additionally, removing the battery exposes inner screws that might need to be removed to replace other parts of the robot.
  1. Turn the device off.
    • Turn the device off.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Use your fingers to gently pop out the battery. Use your fingers to gently pop out the battery.
    • Use your fingers to gently pop out the battery.
Conclusione
Paul Heli
Membro da: 10/02/2020
287 Reputazione
1 Guida realizzata
Cal Poly, Team S22-G2, Regan Winter 2020 Membro di Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 235
