Salta al contenuto principale
iRobot Braava 320 Wheel Replacement
Cosa ti serve
  1. iRobot Braava 320 Wheel Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Wheel Replacement: passo 2, immagine 1 di 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Wheel Replacement: passo 3, immagine 1 di 2 iRobot Braava 320 Wheel Replacement: passo 3, immagine 2 di 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Wheel Replacement, Body Shell and Control Panel: passo 4, immagine 1 di 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Wheel Replacement: passo 5, immagine 1 di 2 iRobot Braava 320 Wheel Replacement: passo 5, immagine 2 di 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
  6. iRobot Braava 320 Wheel Replacement, Wheel: passo 6, immagine 1 di 3 iRobot Braava 320 Wheel Replacement, Wheel: passo 6, immagine 2 di 3 iRobot Braava 320 Wheel Replacement, Wheel: passo 6, immagine 3 di 3
    • To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
    • The cover should come off as soon as you hear a 'click' sound.
    • When replacing the cover, align the notches on the cover just to the right of the ones on the wheel.
  7. iRobot Braava 320 Wheel Replacement: passo 7, immagine 1 di 3 iRobot Braava 320 Wheel Replacement: passo 7, immagine 2 di 3 iRobot Braava 320 Wheel Replacement: passo 7, immagine 3 di 3
    • Using a small Flathead screwdriver, remove the small black clip in the center of the wheel.
    • To ensure the clip does not fly off, place your hand over the wheel to cover it as you remove the clip.
  8. iRobot Braava 320 Wheel Replacement: passo 8, immagine 1 di 3 iRobot Braava 320 Wheel Replacement: passo 8, immagine 2 di 3 iRobot Braava 320 Wheel Replacement: passo 8, immagine 3 di 3
    • Once the small black clip is removed, the wheel should come off by gently pulling on it.
    • Be careful not to lose the two small chrome pieces located on each side of the wheel.
Conclusione
Altre 13 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Nance Spring 2017 Membro di USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Membri
10 Guide realizzate
Un commento
O roteiro descritivo para a troca das rodas do Braava foi muito Ăștil. Obrigada!
Vanilda Chueiri - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 43
Tutti i Tempi: 9,736
